Old 01-17-2011, 04:30 PM   #11 (permalink)
Nevyn
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
We have a MAP sensor (Manifold Absolute Pressure) not a MAF (Mass Air Flow) sensor, so if you're looking for info, see what has worked for other MAP based ecomodders. 01 should be an XD (same shape as mine?). The intake has a resonator channel on it - you can remove the resonator channel and close it off, or you can remove part of it and use the rest towards a WAI. I've found (via ScanGauge) that the temps where the "butt dyno" says/feels that the car runs best is relatively low - 65 to 85 degrees F it feels like it has the most power for the punch.
If you haven't, change the ATF. There's a drain plug, and you may even have a spin-on filter (like an oil filter). ONLY use SPIII from a dealer - you can get it from Hyundai, Kia, or Misubishi dealers. Call around and ask what price they'll give you if you pay cash and buy a whole case - you can get it for about 1/2 price that way. It'll make a BIG difference in shift feel.
