You can swap the muffler for a straight pipe for more weight savings and an even flatter underbody for the bellypan. With the TDI, the turbo and cat quiet the exhaust nicely. I did it on my car and it is not loud. You may notice a nice whirring noise if you stand by the tailpipe at shutdown.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
