cortez - if you look at 1 of my previous posts on here you'll see that i said i only used like 1/3 of a gallon through the jar to 3/4 of a tank so the usage is quit small on mine so accounting for the added gas isn't really possible you know
swiftbow - yea i was thinking psi but i was looking online and was told vacuum is in inch pounds so i went with it but i thought it was kind of wierd for a vacuum pump manufacterer to go with psi if it only used inch pounds so i was told wrong
cortez - the jar only adds gas in it's atomized form so then it burnes almost instantly in the combustion starting the burning of the injected droplets of gas quicker so they burn more thoroughly or so i've read, so then the lower amount of o2 in the exhaust tells the computer that your running rich and leans out or so i'm also told.
