Old 01-28-2011, 10:32 AM   #25 (permalink)
KamperBob
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by sid View Post
No, the rear doors barely clear the top garnish. The photo is slightly looking down on the back of the truck, which gives the perception that the doors are too tall. Clearing the doors is the reason the top garnish is only 10 degrees and not 12 degrees like on the sides.
The utility of your cap cannot be beat. Especially if both doors open wide enough to carry full 4x8 sheets of plywood, drywall, etc.
From your pix it looks like your garnish does not have any blend radius between approach and tapers. If so, they don't help aero. They may help keep the rear doors cleaner and drier though.
Recreation Engineer
