Also something like stainless steal wool will help spread the heat in the water and if the SS sits higher than the water it will reduce the splash of the bubbles. A plate could be placed in the jar with a hole on the opposite side from the outlet. So top right exit, then a plate below with a hole on the left side for gas to flow below that is an air gap then the water with the EGR pipe running in to it.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
