Old 10-28-2010, 08:21 PM   #41 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I suppose we (general public, not ecomodders!!) couldn't be relied upon to keep a water tank topped up for no apparent gain.
Old 10-29-2010, 04:33 PM   #42 (permalink)
...beats walking...
...interesting, that's exactly the problem that Oldsmobile experienced with their original "Turbo-Rocket Fluid" for the 'Turbo Jetfire' engine back in the 1960's:
"Turbo Jetfire -- In 1962 and 1963 Oldsmobile built a turbocharged version of the 215. The small-diameter Garrett T5 turbocharger was manufactured by Garrett AiResearch and produced a maximum of 5 psi (34 kPa) boost at 2200 rpm. The engine had 10.25:1 compression and a single-barrel carburetor. It was rated at 215 hp (160 kW) @ 4600 rpm and 300 lb·ft (410 N·m) @ 3200 rpm. The high compression ratio created a serious problem with spark knock on hard throttle applications, which led Olds to use a novel water-injection system that sprayed small amounts of distilled water and methyl alcohol (dubbed "Turbo-Rocket Fluid") into the combustion chambers to cool the intake charge. If the fluid reservoir was empty, a complex double-float and valve assembly in the Turbo-Rocket Fluid path would set a second butterfly (positioned between the throttle butterfly and the turbocharger) into the closed position, limiting the amount of boost pressure. Unfortunately, many customers did not keep the reservoir filled, or had mechanical problems with the turbocharger plumbing.
The turbocharger was offered only in a special Jetfire model, which was the first turbocharged passenger car offered for public sale. Only 9,607 were sold in two model years, and many were converted by dealers to conventional four-barrel carbureted form."
[Wiki]
Old 01-27-2011, 01:54 AM   #43 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
i was thinking someone needs to see what happens when you put a jar of water inline of the egr supply line cause the water evaporates at 212 degrees and that should also act as a soot and particulate filter by putting the gritty stuff in the water and heating the water into evaporate so it's also like a water injection(by putting the jar of water right after the exhaust manifold it should almost eliminate the need to clean you egr valve and other parts!!!) also if you have to much gas bubbling through the water in the jar you could get to much water in the engine so get a tube thats the same diameter as the egr supply line and rap it in a spiral at the bottom of the jar and put like 1/8 inch holes every 1/2 inch around the spiral so that you will have the proper amount of eg through the jar without over bubbling and the smaller bubbles also allow more cleaning of the gases.
The Following 2 Users Say Thank You to stovie For This Useful Post:
ShadeTreeMech (01-27-2011), UFO (01-27-2011)
Old 01-27-2011, 11:32 AM   #44 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
with a deep enough reservoir of water, that could work to clean out the grit. I'd been contemplating increasing the egr amount to save fuel, but didn't want to dirty up the engine. Bubbling the exhaust through water ought to do it!
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 01-27-2011, 12:37 PM   #45 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
That sounds like a good idea! Let the car breathe through a water pipe.
I'm not coasting, I'm shifting slowly.
Old 01-27-2011, 12:43 PM   #46 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Air can be compressed, fluids cannot. I do not want to be the first to experiment with hydro-locking up my diesel engine. Proceed with caution. The EGR pipes on my car are 1" or 25mm. That could suck up a lot of water.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 01-27-2011, 01:30 PM   #47 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
The problem with this approach is you would cool the water vapor in the exhaust gases below boiling point and condense it. This means you have to expend energy to over come the energy of enthalpy again to convert it back to steam during combustion.
Old 01-27-2011, 09:10 PM   #48 (permalink)
connclark - the main reason for the water is to filter the crap out of the exhaust gases in my opinion the bonus is added water vapor in the combustion to hopefully lower combustion temps for lower nox and the exhaust gases that are going into the jar are usually about 300 degrees so that should actually get the water itself to within range of it's boiling point so it reduces that
COcyclist - there's really not that much risk of sucking up water into your engine if you set the jar up properly you have it about 3/4 of the way full with a spiral that only lets little bubbles through so it doesn't bubble to your supply line thats only in the jar about 1/2 an inch i have this set up on my jeep but instead of water i have fuel in the jar but no exhaust gas flowing through just air
Old 01-28-2011, 04:17 PM   #49 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Also something like stainless steal wool will help spread the heat in the water and if the SS sits higher than the water it will reduce the splash of the bubbles. A plate could be placed in the jar with a hole on the opposite side from the outlet. So top right exit, then a plate below with a hole on the left side for gas to flow below that is an air gap then the water with the EGR pipe running in to it.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 03-12-2011, 08:17 PM   #50 (permalink)
i put a jar of water on my jeep and ran the exhaust gases through it, so far it's quited the exhaust(that i cut off 3 feet from the exhaust manifold so it was pretty loud) to where it sounds like i have a flowmaster on. it smoothed the idle and so far i'v noticed a 4-5 mpg increase, i'll let you now how it does.
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 11:43 AM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 01:45 PM
Hey Civic VX owners - I need your help - please test your egr valve jadziasman Off-Topic Tech 5 06-27-2010 08:56 AM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 10-01-2008 12:11 AM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 10:11 PM
