Old 01-28-2011, 06:36 PM   #2 (permalink)
pounsfos
Laura the Lancer - '81 Mitsibishi lancer LX
as long as the pistons are the same bore size as the ones you want to use then go for it.
rocker assembly and camshaft design has nothing to do with the pistons.
a good example is my 1.2L motor and the next model up (the 1.3L motor) have different rocker assemblys (still both pushrod design though) and you can swap them around no problem.
just my 2c
