After read this It 50% BS.
I know that ALOT vapor in tank but problem is Ford use those check ball valve in tank so that won't work with vacuum it would pull check ball then it would died due no fuel go to engine due tank lock in vapor.
I believe that heat gas could improve mpg little.
Now we are in 10oF so gas burn QUICK. I have been look for electric heater on fuel filter but haven't found yet.
