Old 01-31-2011, 01:36 AM   #8 (permalink)
The Rooster
He ain't gonna die!
The Rooster's Avatar
Tree Catcher - '94 Acura Integra LS
90 day: 32.12 mpg (US)
The Old Dog - '92 Honda Accord LX
90 day: 31.58 mpg (US)
All things being equal, bigger engines burn more fuel, and the Teg's 1.8 has no trouble moving the car as it is, mine anyway never strains. I can usually accelerate up hills in 5th gear, or at least maintain speed on steep hills in 5th. To make a larger engine save fuel, you have to spin it at a lower RPM, which means you could have better luck sticking with the stock engine, and doing something about the transmission to make your gears taller, rather than putting in a larger engine. A M/T swap would be cheaper, easier and more effective in your case.
If you drive your car modestly and aren't doing a lot of hill driving or towing, the small opening should be fine, the AT isn't going to generate a ton of heat unless its working, aka the torque converter is never locked up.
She was beating on my door for two hours last night...but I wouldn't let her out.
The Following User Says Thank You to The Rooster For This Useful Post:
Darkrider (01-31-2011)
