Originally Posted by rmay635703
As for laptops, I would have to then carry a 2nd monitor as our booth layout simply wouldn't allow me to quickly, easily and safely show the customer the poem, information or image. Also the laptop is very very likely to get damaged...
Not true. What you need to do is think of the laptop as the system. You keep it closed, maybe under a counter (or wherever you'd normally keep your desktop unit), and plug in external monitor, keyboard, & mouse (or use wireless for those last two). The laptop is probably more rugged than any desktop, lighter, and more power-efficient, because it has been designed with those qualities in mind.
Also, most laptop processors have a sleep mode which essentially turns the CPU off when there's no work to be done. I use Linux, so I don't know how this is controlled on a Windows system, but you might look at the Powertop utility for ideas on minimizing power use.
