Auxiliary AC fan, with or without
Thinking about removing aux fan in front of radiator which operates when AC is on, works using temp sensor which means if temp is cold the fan stops spinning. When I drive the car with AC is off the fan basically inhibits air flowing into radiator. This might help avoiding drain up the battery as it reduces electric consumption and at some extent helps mpg. When I need the AC it runs without the aux fan, wouldn't this do any harm to the compressor and AC system?.
Thanks
Reason: efa
