Old 02-02-2011, 01:59 AM   #441 (permalink)
billhac
billhac's Avatar
nEon - '96 dodge neon
good for you wolverine, you test and post honest results, I did my own hho testing back about 2 years ago, I still hear the same arguments, though valid, I kept an mpg log, and even put the car on the dyno, I kept the results, but if you keep testing be prepared to give valid results or you wont be taken seriously, and even with an mpg log and valid results, you will still get skepticism from some. first problem is how do you acquire enough power to generate enough hho to give you the results you want. remember you cant get more out then you put in (not my idea, just physics)
