Old 02-03-2011, 01:05 PM   #449 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by tangomar View Post
Ions, think at them like the depletion zone in a semiconductor barrier. There is a built up field because of these ions.
Using PWM you build and remove it.
Regarding the high voltage effects I need to find the paper that was indicating higher Faraday conversion efficiency using high voltage in electrolysis...
Thank you for the rephrasing. That makes a bit more sense. But understand we are still talking about a marginal improvement on an endothermic process, and you will never recover 60% of the work you put into it.
