well I just want to chime in here and first say you are right, I know that im asking for trouble, but though it is not possible to get out more than you put in you can infact get some performance gains with the proper set up, for example, if you upgrade the alternator to a higher amperage and add a second battery, that is only charged from the upgraded alternator, and only use the hho generator from the second battery, you can produce enough to see some gains to make a difference. the motor will work a bit harder to charge the second battery, but not enough to cansel out any gains. just my .02, speaking from experiance. not 60% as you say but 25-30% which is good when gas is $3.07 a gallon
