Old 02-04-2011, 05:02 PM   #4293 (permalink)
shortcircuit
Originally Posted by MPaulHolmes View Post
Hi Short circuit! Number 5 is alive!!!!!
You need analog signals converted to pwm? Like a throttle converted to pwm? What's the voltage on the scooter? You could probably just use something like a 7805 if the voltage is less than 35v, and power the micro with that. IT could be really really cheaply done.
the OSMC can drive anything from 6-48V (I think) but it's input is 5V
I was thinking of using either an arduino, or whatever the circuit is that you are using.... (because I need to program in ramp-up to speed and max throttle knob. )
do you have a schematic (and possibly a board) for just the microcontroller part?
