Old 02-06-2011, 02:26 PM   #63 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Good news So it seems to be true that VW (and Audi) started to comply to OBD earlier than necessary.
Idle consumption looks OK, Euromodder and I both have the same engine (1.6HDi) and we both see idle consumption around 0.5 l/h.
You will have to calibrate the SGII at each fill-up, after a while it should be close its target. If not, you may try the trick with engine displacement reduction. Take into account that the ScanGauge is harder to calibrate with a diesel than with a gasser.
