Old 02-06-2011, 02:51 PM   #65 (permalink)
Arragonis
The PRC.
Originally Posted by Arturasz View Post
Another question: moving SG to another car is pain in the arse? Or i need each time to readjust it?
Pain in the Arse if you are swapping back and fro. If the change is for a while then you re-calibrate.
Also setting the engine size to something like 1.6 gets you closer to reality in the 1.9, and then adjusting to 1/2 way between the estimated fillup and the actual gets you closer.
Using this my last tank was 1.5 MPG out SG2 vs real world, which TBH is probably not bad given no ventectomy on my Fabia - yet.
