Old 02-08-2011, 06:27 AM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Instead of swapping in a smaller alternator, replace your battery with a larger one (deep cycle) and put a kill switch on the alternator. That way the oversized alternator can charge the battery only when needed, like when engine braking. Check out these two threads:
Automatic alternator cut out/regen braking
Deceleration Alternator
If you want to address the fan and spinning losses that George Tyler mentioned, then try an A/C clutch pulley - it's been talked about, but I don't know if it's been done.
