Old 02-08-2011, 07:53 PM   #9 (permalink)
IamIan
IamIan's Avatar
Arrow
Originally Posted by canuck111 View Post
I have built a pretty good electrolyzer and can create the gas.
What performance specifications have you achieved?
What kg of water input electrolyzed per hour?
What electrical input per hour?
Understanding why and how it works has led me to a possible solution to running a vehicle on just HHO not as an additive.
If your source of electricity comes from RE it will be cleaner than Gasoline.
A BEV will travel further on the same amount of input electricity... ICE efficiency it very low.
As far as heat is concerned there is very little evidence of heat in any of my experiments.
A brown's gas torch works on different principal. It uses atomic hydrogen/oxygen. This is why these torches operate at about 270 degreesF
Can't have it both ways ... if the chemical reaction produces heat in the torch ... the same chemical reaction will produce heat in an ICE.
Correction to your post:
'brown's gas' torches can produce flame temperatures up to 2,800 Degrees C ( 5,072 F ) when premixed in a 2:1 ratio with pure oxygen... 270 is on the extremely low end.
