Old 02-09-2011, 12:05 AM   #6 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
a crank scraper is a good idea, but it wouldn't be needed if you drained the oil from the crankcase.
Sarcasm I hope...
As far as reducing horsepower requirements to get more mpg it would be better to use a dry sump with crank scrapers and or windage trays, as these would reduce the amount of HP needed for the crank to rotate.
