Originally Posted by pounsfos
as i do dyno tuning when i get a mod done.
the guys at my dyno shop are into there v8's
they have a car with dry sump, lumpy cam, and an ecu flash
they said the dry sump only gave them about 14kw.
btw there car makes about 470ishkw so yeah
Dry sump oil pumps have more drain on HP then wet sump oil pump .
There is a vid of big block wet sump on dyno that they remove 1 qt and it gained noticeable amount of hp. this was large wet sump i believe 6qt ,so they ran 5 qt .
