Originally Posted by Jim-Bob
Point well taken. Had I not been having a rather bad week I likely would have followed my own advice and walked away at that. I should have but I couldn't avoid picking apart the failed logic I saw in the post. I shall recuse myself from further dealing with this troll.
I think I could sum it up simply with two rules;
1) The ONLY time you should respond to a troll is when its for the amusement of yourself or the other members of the forum.
2) Arguing with a troll only amuses the troll.
The easiest way to accomplish the former is to take it up a notch. If he says he has a 10k lbs truck, counter him by saying you have an International semi that runs on a WWII V-12 aircraft motor from a tank that runs on Jack Daniels.
Trying to make an intelligent argument with a troll is actually the stupidest thing you can do...because that's EXACTLY what he wants...so he can continue to troll you.
I'm starting to realize now that I've spent way too much of my life on the internet...it's the only explanation to how I know the in's and out's of trolling...unless...
