Old 02-16-2011, 08:44 AM   #32 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by stovie View Post
on anything else i'd say go with the science but this is something that has to be done personally to be proven i will admit that if your trying to seperate hydrogen and oxygen using electrolysis then ya it's going to take more energy then you'll get back from burning it BUT if you forget about seperating the two then it's easier to make lots of hydrogen and oxygen from it and also you have to have a electrolizer in the water to allow easier power transfer through the water. take like 5 plates put them 1/8 of an inch apart in sequence and put about 1/2 a cup baking soda to 1 gallon destilled water then put power to the outer plates and see how much hydrogen and oxygen is created, i'm sure it's not that much to get 5 plates and test it so you have your own proof weather it works or not. I got my proof and your not going to change my mind cause i've done it first hand!!!!!!!
I think I will fly away on my magical unicorn now...
