Old 02-17-2011, 01:11 AM   #17 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Originally Posted by 93_VX_Guy View Post
Could you shed light on how to do this? Is it a matter of hacking the harness at some point between the shock tower and the 02 plug (so only one plug is needed) or would I need to create a 2 plug harness from the shock tower to the sensor?
Since I haven't done it, the best I can do is give you vague guidelines... basically get the wiring diagram out and cut & splice so that the 5-wire O2 sensor connects to the correct pins on the ECU. How that is accomplished is going to be up to the individual.
