Thread: battery booster
Old 02-17-2011, 09:12 PM   #11 (permalink)
gabi
thanks for the responses,
so i will have to set the imput of the pack at 14.5 volts or above.That could be done,
each battery has 12 volts,
i will wire them in series,and that gives me 24,all i have to do is lower it
my cigarette lighter fuse is 15 amps,i could prob change to 20,or 25
the switch will work in reverse of an alternator kill switch,
insted of killing the alternator, i kill the buster imput to the main battery so the alternator can come on,as it senses less curent.(down the hill, when breaking...etc)
i can use a manual swich for that.
that would extend the range of the buster pack
about the weight, they only weigh 1 lb each,so i'm not concern about that
