Old 02-19-2011, 06:36 PM   #37 (permalink)
watercat
The green machine - '94 Geo Metro
I must be a total retard
I read these fuel numbers and have convinced myself there all lies. I have 42mpg best on my new engine. I have the kill switch the higher compression the 50 psi tire pressure i no longer pick up fat chicks hitch hiking. i also installed te manual throttle which should really help out my kill switch coast. not a single mods seems to have helped at all? infact i got this mpg before i restored the machine.
I just installed a big wink mirror inside and will be ditching the outside mirrors. also prettyt smooth hub caps.
I was think i could get rid of the glass and seats in side and where a helmet to reduce weight and maybe some drag?
I also considering driving over the car with a monster truck to help with the drag issues.
i did build a tow bar to tow geo's i find dead home and i can say its time for a rear disc brake kit when towing and a turbo or maybe a NOS bottle for coming out of the hole and up to speed.
I have a hummer H2 with a tow bar for it i think i'll hook it to the geo and post a picture of the geo draggin it down the road.
You super MPG guys are you running the stock 12' tires? and the air dam in the picture on your red geo is that almost to eth ground i dont understand about the 6" or 4" off the ground you mentioned.
I've never felt so disappointed with 40 mpg.
