Old 12-20-2010, 12:43 AM   #31 (permalink)
tire pressure
I drive a 92 LSi and have my tires at 35psi, is this to low then?
Reading your story you mention you rears at 38psi and the fronts at 45psi? Tell me if I need to change mine, thanks!
Aaron
Old 12-20-2010, 01:48 AM   #32 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
You're better off inflating your tires to maximum sidewall pressure if your goal is strictly mileage. Some people exceed that considerably. But you may not want to go as high as maximum sidewall pressure if you're driving on snow and ice.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 12-20-2010, 03:08 AM   #33 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
No more than +5 psi from recommended is what I'd suggest. You certainly don't want to blow it. Especially since I doubt your carrying a spare or jack.
VT247
Old 12-20-2010, 05:10 AM   #34 (permalink)
Work In Progress
Black Knight - '08 Toyota Yaris
Send a message via AIM to honestabe
I have ran my 95 Geo Metro's tires (rated at 36 PSI) at 45 PSI for the last 15000 miles with no problems (and I've driven 75 MPH like that).
Old 12-20-2010, 05:20 AM   #35 (permalink)
Forgot to mention the weight of the vehicle plays a role in how much PSI to add as well. Your Metro probably weighs less than a ton (2000 lbs).
VT247
Old 12-20-2010, 05:26 AM   #36 (permalink)
Work In Progress
1751 lbs according to KBB.com, so 2000 lbs with me in it.
Old 02-19-2011, 05:36 PM   #37 (permalink)
The green machine - '94 Geo Metro
I must be a total retard
I read these fuel numbers and have convinced myself there all lies. I have 42mpg best on my new engine. I have the kill switch the higher compression the 50 psi tire pressure i no longer pick up fat chicks hitch hiking. i also installed te manual throttle which should really help out my kill switch coast. not a single mods seems to have helped at all? infact i got this mpg before i restored the machine.
I just installed a big wink mirror inside and will be ditching the outside mirrors. also prettyt smooth hub caps.
I was think i could get rid of the glass and seats in side and where a helmet to reduce weight and maybe some drag?
I also considering driving over the car with a monster truck to help with the drag issues.
i did build a tow bar to tow geo's i find dead home and i can say its time for a rear disc brake kit when towing and a turbo or maybe a NOS bottle for coming out of the hole and up to speed.
I have a hummer H2 with a tow bar for it i think i'll hook it to the geo and post a picture of the geo draggin it down the road.
You super MPG guys are you running the stock 12' tires? and the air dam in the picture on your red geo is that almost to eth ground i dont understand about the 6" or 4" off the ground you mentioned.
I've never felt so disappointed with 40 mpg.
Old 02-19-2011, 06:04 PM   #38 (permalink)
90 day: 51.82 mpg (US)
I have no trouble believing 75 mpg is possible from these cars under certain conditions.
Post #9 explains how he did it. Also note that he got these numbers in summer conditions, and with aeromods in place.
That would definitely reduce frontal area. If you pursue this aggressive mod, please post on YouTube.
Old 02-20-2011, 02:53 PM   #39 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
hey watercat. I think if you took a ride with some of us whackos you'd see how we get these "unbelievably" high MPG numbers. 99.99% of the people out there CAN'T/WON'T drive the way some of us do to get great fuel mileage.
I think you have a 1994 3/5? Do you have any MPG feedback, like an MPGuino? With a fresh engine and light right foot, over 50 mpg should be a piece of cake.
Old 02-20-2011, 10:41 PM   #40 (permalink)
in all seriousness i am trying. I had the block bored 40 over put in pistons and total seal rings. installed bronze guides and stainless valves, put in the 4 cylinder fly wheel and clutch kit had the crank turned 20 and the front pulley to the pressure plate all balanced together. I have set all specs basically at stock right now and advanced the timing 5 degrees a few days ago to see what timing would do a few more each tank. I'm running the cheap fuel with 1o% alcohol in it which cant help. I also raised the compression to about 11.5 or so and cut those sining or what ever he is called grooves in the head i read on here. My best is 42 mpg so far but i seem to fall in the 38 all the time. this is not my first geo i have had way to many and even a brand new one in 1990 which i just got rid of a while back. I thought i checked my gas mileage before and got better but now i'm starting to think that keeping a log book is showing me the real deal of about 40 when i thought it was about 50mpg. this week I'm going to tape off the grill and remove the mirrors. Also i just switched to atf with prolong additive in the trans axle to make that as thin as possible and i have a5 something synthetic in the engine. plus i installed the teen speed bike shifter for a throttle on my gear shifter and a kill switch for the injector/cam sensor. Its even a green metro color, if red makes them faster green should make them more efficient.
It has to be a lot in the driving technique and i honestly have not even started reading on the hyper mile aging or what ever its being called. I do try and drive 50 to 55 all the time as well.
what is a good timing setting and i have read lots about cam changes etc and cam gear changes but no one has said that i have read this is for sure the way to go.
on a positive note i just bought a electric geo and will have it this week i hope with all new batteries so i can be disappointed with range and top speed instead of mpg.
next mod cut hole in floor to help push with both feet.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 06:48 PM
Tuning an 1993 Geo Metro Up from 32 MPG. Zorro DIY / How-to 6 04-29-2009 08:18 AM
1990 Geo Metro hatchback; improved mpg 90metro Success Stories 9 04-07-2009 09:25 PM
