Carlo, Check your connections to both the starter and the ground to the block as well as frame. Being on the left cost you don't get the issues i get in Jersey with salt air and temp expansion terminal ends and corrosion is a problem if not maintained.
What you described is common had it happen to my truck once this year and my neighbor asked me for help his terminals were loose and a friend was stuck they had a lot of corrosion. I hope it is that easy of a fix for ya.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
