Thread: It's working...
Old 02-25-2011, 07:04 PM   #13 (permalink)
MGB=MPG
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
Dart Lite
I run my 79 B as a daily driver .. if you are about net global saving fuel think how much fuel is saved by keeping a good machine running instead of buying a new one , how much energy/fuel is consumed in the production of a new machine, more than you will ever save by buying one i think. cast aside the throwaway ethic sold to you by industry that only has a 12 year life cycle on the machines. 36 MPG is not shabby for a big Coupé.
the brown paint looks good a shame you did not just buff it [ at least to me]
and put the cash for painting on engine parts and whatnot
the badge Lite interested me so i looked it up. saw yer string on the dodge form and cut the pic in did not read string.
rated at 36 getting 18 is awful somethings not right
carb or ignition or something needs more attention,
how do the plugs read , does it have a points type dizzy ? is the carb squared away , how is the cylinder compression?
likely the special part of the dizzy is the advance curve and after 35 years the springs are tired and stretched the vacuum advance is bad and its gummed up . that is unless you have overhauled it.
i know a guy that will rebuild that and put a custom curve on it any way you like, it will work better than new, costy but he does world class work , people ship ddizzy from OZ & the EU for him to overhaul.
""distributor recurve may be the "missing link" to great performance from YOUR engine!!""
Advanced Distributors: Distributor Repair at its Finest!
when the dizzy is squared away , timing set at the proper advance , then the carb,,, i am curious about the *special * nature of the carburetor.
i run a special carb a SU HIF 44..
clean and adjust that carb and lean that baby out ,, not to lean or you will burn valves ..
if i had that machine i would have Fuzzy Dice hanging from the rearview and Hula Girls on the back shelf..
are those beauty rings on steel wheels ,, like they say in ANAHEIM, that girl would look Chaste with Full Moons . i have a set on the LA-Memphis run Rat now.. worth 4 % FE so said.
