Old 02-25-2011, 07:09 PM   #19 (permalink)
oldbeaver
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Adjusting the nut behind the wheel TDI improving
Originally Posted by rfdesigner View Post
As a diesel owner. may I suggest a some suitable easies.
Therefore I can reccomend a grille block, it does three things for diesels.. it helps improve aerodynamic drag, it helps reduce the airflow over the engine which means improved warmup time, and a curious bonus I've discovered is that if you seal it in, it helps reduce heat loss when the car is parked. Thus the engine is a couple of C warmer in the morning. I strongly suggest blocking the UPPER part of the grille, not the lower part.
Adjust the nut behind the wheel.. let's assume you've done that.
check your Mass Air Flow sensor and your Exhaust Gas Recirculation... which often get horribly coked up.
Derek
Dear Derek,
Your advise makes a lot of sense to me.
I have a Skoda Octavia 1.9 TDI, and have done:
- Upper grill cover
- Rear wheels mud flappers removal
Please, can you explain what is "adjust the nut behind the wheel"?
Maybe a picture?
I am very interested about learning how to check/clean the MAF and check the exhaust gas recirculation. I ordered a VAG cable & software to plug into my notebook.. Do you thing these systems can be checked with the software before removing them?
Tks.
Oldbeaver
