Old 02-26-2011, 02:59 AM   #92 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
I have a new metro clutch disk, and it doesn't fit the splines on the Samurai trans. What I'm considering doing is remove the spline part of a Samurai clutch disk and put it inside a metro clutch. This means destroying them to get at the splined part inside to swap them.
Anyone have a good metro clutch disk they can donate to the cause?
Maybe I can see if I can buy just the disk..
Originally Posted by darcane View Post
You should be able to return parts to the auto parts stores if they don't fit. Buy it and give it a test fit, return the Metro parts if it doesn't work out right and use the heavier Samurai stuff.
