Old 02-26-2011, 09:19 PM   #27 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
You have a working motor that needs a body??
Originally Posted by bockwho View Post
im a lurker but...
the special parts of this car is the head, intake, computer and higher geared trans...
And the wideband oxy sensor. Not sure there's anything special about the intake, unless you count my warm air intake mod. Dremel cut holes in the air filter housing to pull in air heated by radiator, that's all it is.
Yes the tranny is geared tall but I think the DX and maybe some others had the same ratios. I think you can find that info per each "trim level" model on autos.com under "research" if you want to chase it down.
Coast long and prosper.
