Old 02-28-2011, 08:21 AM   #47 (permalink)
Freyguy
EV Builder
Freyguy's Avatar
Originally Posted by harlequin2 View Post
Yeah, they aren't too bad. I have added that up to 10 boards already - correct me if I'm wrong. So I'll get an order underway for 15 as there are bound to be a few more. When I receive them, I'm going to build mine before I send off to the others so I can be FIRST!!!!!
I have a PICkit2 so I can program the chips too. If anyone wants to buy already programmed micros let me know and I'll get a few extra.
Programming for others would be involved. Individualized settings make it so:
-Traction battery capacity
-Peukert exponent
-MTE setting for particular EV (pmile parameter)
-vpack trim to compensate for individual U5 transfer gain tolerance
-profiles
And you will most likely find yourself needing to go back and "tweak" some of these values for better tracking accuracy.
Preprogrammed PICs would be fine to get someone started so they can see that their assembly efforts were successful, but builders should definitely consider investing in the PICKIT2 (or clone).
BTW-Like the reason for your edit
