Thanks for the O2 sencer Idea I like it. I was also thinking about instaling a vacume guage, but finding a mounting spot on the existing dash is a problem. I have a plan to expand the dash board to accomedate more stuff like the above two, plus indoor/outdoor digital thermometer w/clock and GPS/data logger. As for cam timing I don't have the time for that this year and I suspect the present todo list is overburdend!
I have never been a big fane of changing Jeting on carbs unless you have some way of monitering. In my case I am making so meany other changes that are of greater benifit for FE that playing with the carbs at this stage is ill advised. After I get the O2 and other guages in place I may find evidence to make jetting changes.
