Old 02-28-2011, 07:55 PM   #74 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arturasz View Post
After few weeks there will be 1200 km eco rally,
Are those thirsty Fiat 500s coming again ?
Even I could beat them
Have you got more details ?
what tips for VW Lupo. Can i use with it Pulse and glide technique
If you haven't tried pulse and glide, I wouldn't use it on an eco rally.
Try it first, and see if it works.
See if it really works, not if works on a Scangauge !
The Scangauge will display faulty, low values when it isn't calibrated using pulse and glide.
Can I switch off engine before downhill and go to neutral gear?
If you don't need engine braking to keep the speed under control, you certainly can.
You'll lose the powersteering and brake assist !!!
