Old 03-02-2011, 08:57 AM   #76 (permalink)
Arturasz
Audi - '97 Audi A6 1.9 TDI
Originally Posted by euromodder View Post
Are those thirsty Fiat 500s coming again ?
Even I could beat them
Have you got more details ?
Meanwhile not so much, but it will be in March, and will be 15 max participants.
If you haven't tried pulse and glide, I wouldn't use it on an eco rally.
Try it first, and see if it works.
See upper post, i don't know how to do this, nowhere is written, procedure of it.
See if it really works, not if works on a Scangauge !
The Scangauge will display faulty, low values when it isn't calibrated using pulse and glide.
Meanwhile SG2 shows very optimistic figures. I.e. in very cold month, it shows tank average 5.2 l / 100 km, despite fact, that i drive in short distance, when engine coolant reaches only 30-40°C.
If you don't need engine braking to keep the speed under control, you certainly can.
You'll lose the powersteering and brake assist !!!
Lupo doesn't have power steering And braking is not big issue in ecorally, cause if you use brake = you loose
Audi A6 TDi
VW Lupo 3L
