Old 03-02-2011, 02:03 PM   #7 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Aerohead says to make sure you have attached flow coming from the front or the mods at the rear won't be very effective so my personal rule-of-thumb has been to work from the front to the back. That said, you should have good attached flow over the roof so I guess it is personal preference what you do first. If you can make it quickly removable, hopefully we can see some A-B-A test results too.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
