Old 03-04-2011, 01:35 AM   #51 (permalink)
byte312
drawkcaB ti toG
Yes, there was a misunderstanding above somewhere somehow.
And, true that there is no such thing as more energy out than energy in.
There is such a thing as waste which may be recoverable. Devices which raise effeciency are worth testing and what works for one of us should work just as well for others if the experiment is dupicated with accuracy each time.
A good test deals with averages of data over a long period of time. A large data sample will create a better picture. One trip to the gas pump, a 5 mile drive and back to top off the tank is not a good test. Tests should be conducted independently by a reliable party that has credibility and the credentials to report accurate test results.
