Originally Posted by ktaylor
If the case is that the sidewall on my car tires is in fact 81 psi, is it reccomendable to go that high? It sounds somewhat dangerous...one bump and they would tear apart from the inside out or something.
If the tyres are rated for the pressure and weight, they won't tear apart on a normal bump.
Run flat tyres are very sturdy.
And heavy.
