Originally Posted by ktaylor
I'll take a look again today but am 99% sure it said max 81 psi at 1450 lb load. The tires are snow rated "all weather" tires (different from all season) and cost me $225 a piece. They are also low rolling resistance and you can drive 40 mi on a flat on them.......
Are you saying they are RunFlat tires? (or since you're from Vancouver - tyres?)
I just looked at Nokian's web site and while they do make Run Flat tires, I don't think the ones to fit your Regal are.
.........They are not Truck/Van tires but since noticing the high sidewall max I starting looking at friends tires and know what you mean. My girlfriend has an 04 echo whos sidewall max is 40 psi but my friends flatbed mitsubishi fuso has max sidewall of 80 psi.........
OK, here's the deal: Passenger car tires will have a max sidewall pressure of either 35 psi (or 36 if the tire is based on the metric system of measurements), 44 psi, or 51 psi - for all standard load tires. or 41 or 50 psi for Extra Load tires.
So if the tires in question are for your Regal, it does not make sense that they would say 81 psi max!
But it does make sense the the LT tires on the Muso say 80 psi max. That makes them Load Range E's - very appropriate for a light duty truck.
.......If the case is that the sidewall on my car tires is in fact 81 psi..........
Before we go there, let's clear up what it actually says. There is some amount of quirkiness in this and it is important we start off with good info!
