Towing a Wildfire from Chicago to California: NO PROBLEM!
http://www.cleanmpg.com/forums/showt...t=24446&page=6
![](http://i714.photobucket.com/albums/ww148/Pterosoar/SmartWildfireWY.jpg?t=1251737587)
3B21-smart fortwo (North American version)
Engine type Three cylinder, DOHC
Displacement 999 cc
Bore x stroke 72.0 x 81.8 mm
Compression ratio 10:1
Fuel type Premium unleaded gasoline
Peak power 50 kW (68 PS) at 6000 rpm
Peak torque 92 N·m (68 ft·lbf) at 3000 rpm
COMPARE TO Cultus 1300 G13B
Smart 3-cyl 50 kW vs Cultus 4 cyl 74 kW
Smart stroke 81.8 mm vs Cultus 75.5 mm stroke
Smart torque 68 ft/lb @ 3000 rpm vs Cultus torque 83 ft/lb @ 5000 rpm
COMPARE TO GEO METRO 1000 G10
Smart stroke 81.8 mm vs Geo Metro 77.0 mm stroke
Smart torque 68 ft/lb @ 3000 rpm vs Geo Metro torque 57 ft/lb @ 3200 rpm
>>> The Mitsubishi 1000 is clearly a superior engine!
THE SOLUTION
http://www.ssgti.net/tech/swap.htm
Comments on tires
Do not convert to dualies. Your coefficient of friction will go down and you will jack-knife and die.
