Old 03-05-2011, 08:44 PM   #31 (permalink)
I was about to put a bunch of quality advice down on the slim chance he isn't trolling, but upon further reflection, I think this case is futile.
Old 03-06-2011, 03:13 PM   #32 (permalink)
EcoModding Newb
trail rig - '02 dodge ram 1500 sport
Last 3: 11.85 mpg (US)
If you have the skill make yourself a bigger intake manifold that can handle one big throttle body (one off a north star v8) and K&N style filter mounted to the throttle body. Just need a vacuum line for your map sensor. Another route would be change out your exhaust to something that lets your motor breath a little better, upsize about a 1/4 to 1/2 inch. Exhaust would be easier; I do not know your skill level with fabrication. Fastest thing that you can try would be; take the entire air box off and just mount a filter to your throttle body (Atv or motorcycle size, foam or K&N style). I did that to my Eldorado and felt like it had a nice increase in power, sounded nice too accelerating.
Old 03-06-2011, 10:11 PM   #33 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
trolling towing ...
trolling towing ... sounds about the same
some people do not know , what they do not know .
and
you can not polish a turd
imho the OP needs a large bucket of TP ( turd polish ) for his un-brilliant idea that many more skilled people have already shown will never work
Old 03-06-2011, 11:20 PM   #34 (permalink)
If you want to know about Geo Metro 1 liters, go to TeamSwift.com. Thats a group of people who specialize in all things Suzuki Swift, which is where the geo comes from, essentially the same motor since 1982, with updates over the years, from carbed to tbi to efi, from dist to crank triggers for ignition. Turbo or non turbo, engine swaps, upgrades and mods. Bike carbs are popular where smog inspections aren't an issue if you want hp, but sacrifice daily driving ease. Look em up
Old 03-07-2011, 05:47 AM   #35 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Itbs are sure to remove any chance of low range torque that you might have had using that triple knocker, unless hou do some sonic tuning for helmholtz (SP) frequency and specifically design an intake runner which takes advantage of it and keeps intake velocity high enough to retain a high volumetric efficiency.
You may not like the idea, but adding a turbo that will spool at 2.5-3k rpm and a dump injector on a MAP switch will get you a quick boost in power when you need it, cheaply and safely.
You don't need to be concerned with overloading your suspension if all you're doing is flat towing or dolly towing. If you're trailering at all, install overload springs and rear tires rated for more load than the 155R12 that came stock. You may consider something in the range of a 175/70R13, mostly having ratings of ~1300lbs at 35-40 psi, as I recall. Plenty for your application.
Get yourself an rv brake actuator that hooks into your trailer plug, and a brake controller. This will allow you to use the towed vehicle's brakes to assist stopping/slowing.
Old 03-07-2011, 06:53 AM   #36 (permalink)
On the same note as intake tuning, the exhaust, particularly the manifold, is equally important. "Backpressure" requirements are wholly a myth. Tune a custom header to the rpm range that you require more torque for, then select a pipe diameter and length that will support proper fluid velocity and meet helmholtz frequencies for your engine configuration.
Old 03-07-2011, 08:21 AM   #37 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
Towing a Wildfire from Chicago to California: NO PROBLEM!
http://www.cleanmpg.com/forums/showt...t=24446&page=6
3B21-smart fortwo (North American version)
Engine type Three cylinder, DOHC
Displacement 999 cc
Bore x stroke 72.0 x 81.8 mm
Compression ratio 10:1
Fuel type Premium unleaded gasoline
Peak power 50 kW (68 PS) at 6000 rpm
Peak torque 92 N·m (68 ft·lbf) at 3000 rpm
COMPARE TO Cultus 1300 G13B
Smart 3-cyl 50 kW vs Cultus 4 cyl 74 kW
Smart stroke 81.8 mm vs Cultus 75.5 mm stroke
Smart torque 68 ft/lb @ 3000 rpm vs Cultus torque 83 ft/lb @ 5000 rpm
COMPARE TO GEO METRO 1000 G10
Smart stroke 81.8 mm vs Geo Metro 77.0 mm stroke
Smart torque 68 ft/lb @ 3000 rpm vs Geo Metro torque 57 ft/lb @ 3200 rpm
>>> The Mitsubishi 1000 is clearly a superior engine!
THE SOLUTION
http://www.ssgti.net/tech/swap.htm
Comments on tires
Do not convert to dualies. Your coefficient of friction will go down and you will jack-knife and die.
Old 05-26-2011, 02:17 AM   #38 (permalink)
The green machine - '94 Geo Metro
So far i have switched to silver stone rally tires which grip the road and stopped the pushing around while towing. Still not able pull steep hills at speed but I can slow down a bit and make it. I'm getting better than 25mpg. i also bought a tracker with a 1.6 8v and it gets the same gas mileage as the Geo towing so i know know I'm just short on power. I also put in some springs rubber snubs to stiffen up the springs to make it handle better hauling. The tires are a bit taller which is giving me great free way mileage empty and it makes my 3rd ad 4th gear more ideal for towing. Looking at the weight difference between the tracker which tows very well and its hp rating i can see that I could use just a few more hp maybe as much as 10 hp. its right on the edge. but as far as handling towing it works like a champ and the brakes have plenty to handle the load. I'm only pulling at 55/60 mph. my ford f-150 with a 300 six is 13 mpg or towing. If i wasn't such a metro die hard the tracker is a great tow rig.
Old 05-26-2011, 02:31 AM   #39 (permalink)
I'm laughing at these posts most of you made about how it wont work etc etc and it works so well. keep up the good positive work guys, I love how most people confuse the thought of facts with there opinions and what they think will happen. I also just made a speed run in my metro from Missulau montana to spokane washington with 3 people luggage and it was so have in the rear i had to flare the rear fender bead a bit so it would rub on the bumps in the ****ty road. any how we drove as fast as we could which was 75 barely and up the pass through the mountains in third gear wide open and I got 46/48 mpg. this new motor and raised compression and the signin grooves etc are really starting to come into play and i am able to get way out there with the timing. still playing with it. I didnt even get to use my clutch engine kill switch but the hand throttle came in handy.
Old 05-28-2011, 01:41 AM   #40 (permalink)
Be sure to let us know how long the transmission lasts...
