not a bad idea, the only issue would be the space taken up by the blanket, the car is quite small, and moving the engine back like I have has taken up even more footwell space, I don't think there is even room for carpet!
I do need to shield the transmission from heat too, but may put in some alum sheild on that side along with the wrap, but once again, there is little room. Tight fit everywhere.
Originally Posted by Christ
How about a simple reflective blanket under the floor covering to keep theheat in check when necessary, and you can remove it easily when you would like the heat.
