Thread: Wai
Old 03-08-2011, 03:42 PM   #9 (permalink)
MGB=MPG
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
*conclusive WAI benefits.*
i run Ram Air Cold Induction and know that there are times and condition when i need WAI .. 1# 35 F and humid for Carburetor Icing 2# to enhance heating to Operating Temps on start up #3 You add more choices
it would be easy to fit on my machine [if i could find the appropriate shutter/valve assy to change between the HAI {from an OEM stove on exhaust Manifold #1 [not currently installed]} that pipe measures about 550F
i think i would want an operator controlled flapper/mixing valve adjusted in reference to my Air Intake Temp Sensor [operator reference only . no computer controle ]
from factory it had a Bi-metallic temp sensitive *flapper* one of the sensory pleasures of this type hearing the Ting Ting ting of the flapper on idle.. however 30+ years and the bi-metallic failed and fell away..
RACI and propose Induction temp mixer
OEM DID NOT have RACI
where can i find a durable light weight cable controlled 2 inch pipe mixer valve ? any help?
ID:	7907   Click image for larger version
