Old 03-07-2011, 08:27 PM   #1 (permalink)
gtstanger01's Avatar
The Turd - '01 Hyundai Elantra GLS
90 day: 33.16 mpg (US)
The Brick - '06 Dodge Durango SXT
90 day: 15.35 mpg (US)
The Money Maker - '07 Volvo VNL 780
90 day: 6.22 mpg (US)
The New Money Maker - '07 Volvo VNL780
90 day: 6.84 mpg (US)
Vdub - '12 Volkswagen Passat SE tdi
90 day: 37.78 mpg (US)
Wai
So I got my Ultragauge finally (and I love it) and have been playing around with making a warm air intake. After trying about 4 different designs and not getting anywhere I finally got the ball rolling. The first 3 designs i couldn't get the IAT over 120 deg. Finally success....got the IAT up to around 150 deg. (I stole the design from a metro website but don't tell anyone) Took the wife to school and noticed a huge difference. Of course the power is down but who cares. Idle gph dropped as well from around .19 to i even saw a .15 but mostly .16 to .17 when totally warm. Next step some ABA testing but might be awhile.
Old 03-07-2011, 08:39 PM   #2 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
When my car is warmed up and the AI is less than 100F the gph is .25
From 100-110F it is .18-.19
From 110-130F it goes down to .15
Above 130F it goes back up to .18-.19
Seems like it has a happy place but don't know what it would take to keep it in that range other than an adjustable opening block.
This is with ambient temps in the 70's so summer time might net a block reduction just to keep AI a little cooler.
Old 03-07-2011, 08:51 PM   #3 (permalink)
So far the warmer it gets the happier it seems. I'm going to do some testing when i can.
Old 03-08-2011, 12:33 PM   #4 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Good Job!
Watch your GPH and your LOD during these tests to see if they corolate...
Old 03-08-2011, 01:33 PM   #5 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I did some pretty thorough ABA WAI testing on my xB here. Bottom line: no significant mpg difference, despite raising my intake air temperature 60-65 degrees F above ambient temps, and 30-35 degrees above stock air intake temps. Mine is a MAF system. The only benefits I've heard of come with WAIs on MAP systems, but I have yet to see any scientific testing results from anyone showing any conclusive WAI FE benefits.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 03-08-2011, 02:10 PM   #6 (permalink)
Physics tells you that cold air is denser than warm air, therefore it takes less fuel in warm air to reach 14.7 to 1 afr. I talked to a friend who has his doctorates degree, is a genius has like 180 patents to he name. He agreed and also stated the closer you get to combustion the more efficient an engine will be. I am sure there is eventually a trade off somewhere. I have, and I think Bharvey does too, a MAP system.
Old 03-08-2011, 02:11 PM   #7 (permalink)
and Ty what is LOD?
Old 03-08-2011, 02:26 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
I know the theory, as that's why I did the testing, but got no bananas. I'd love to see some good ABA results proving WAI benefits. Darin's testing at metrompg and mine were both MAF systems, and showed no benefits. Looking forward to your write-up. Show me pics of your set-up, as I have 2000 and 2006 Elantras to convert, if you can show me some concrete benefits. See my write-up in my earlier link, and G/L!
LOD is % engine load as measured by Scangauge and Ultragauge. It allows consistent acceleration to fit your engine's BSFC map.
Darrell
Old 03-08-2011, 02:42 PM   #9 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
*conclusive WAI benefits.*
i run Ram Air Cold Induction and know that there are times and condition when i need WAI .. 1# 35 F and humid for Carburetor Icing 2# to enhance heating to Operating Temps on start up #3 You add more choices
it would be easy to fit on my machine [if i could find the appropriate shutter/valve assy to change between the HAI {from an OEM stove on exhaust Manifold #1 [not currently installed]} that pipe measures about 550F
i think i would want an operator controlled flapper/mixing valve adjusted in reference to my Air Intake Temp Sensor [operator reference only . no computer controle ]
from factory it had a Bi-metallic temp sensitive *flapper* one of the sensory pleasures of this type hearing the Ting Ting ting of the flapper on idle.. however 30+ years and the bi-metallic failed and fell away..
RACI and propose Induction temp mixer
OEM DID NOT have RACI
where can i find a durable light weight cable controlled 2 inch pipe mixer valve ? any help?
ID:	7907   Click image for larger version
Old 03-08-2011, 02:44 PM   #10 (permalink)
What the heck is that setup on?
