Old 03-08-2011, 04:58 PM   #21 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Could it be that cooling is less efficient when going up a hill, due to gravity ? Ideally, the water pump should be able to easily pump the coolant through the radiator, but on a hill, it might be pumping less for the same amount of pumping work.
Just a thought.
Definitely give the upper grille block a try.
