Ethanol resistant materials for the fuel system. Carb'd will be jetted bigger and injected may have bigger injectors. Dedicated ethanol engines have higher compression ratios; flex-fuel engines are saddled with the lower gasoline C.R.s which compromise efficiency when they're running ethanol.
