In this case, couldn't it be done dead-simple, like by mounting a TBI injector pod on an MPFI engine, run the MPFI system on ethanol but with a higher pressure fuel pressure regulator (so that more fuel per pulse escapes the injectors) and use manifold vacuum (or a combination of inputs) to modulate the delivery of straight gasoline through the TBI injectors?
I don't get all this talk about "ethanol resistant" fuel systems, if gasoline already has 10% ethanol and fuel handling parts don't fall apart in 30+ years why would a greater concentration of ethanol make them fall apart? Why would OEM's make fuel handling materials that can be damaged by ethanol when they KNOW a 10% ethanol fuel is going to be in contact with them 24 hours a day for more than a decade? At what point does the solvency of ethanol go from "absolutely no damage whatsoever" to "totally dissolves everything"? 15%? 30%? 43.33331%? And by what mechanism does ethanol go from absolutely zero harm at low concentrations to total harm at higher concentrations?
Work From Home mod has saved more fuel than everything else put together.
