Old 03-10-2011, 05:41 PM   #23 (permalink)
sjr
Metro HotRodder
Originally Posted by euromodder View Post
Do you work from design sketches, or do you go where the project takes you regarding design ?
The width difference is going to require some serious fairing-in to match the rear body.
Keep it going
Ive been modifying unibody cars for over 25 years , I know what I want in the end and just go at it, , I removed 17" down the center on the white car, then took just enough off to get the 2 together keeping stock length , the nose will end up a 1 peice Fiberglass bulb, as I work at a Fiberglass plant that makes Bathtubs
