Old 03-11-2011, 12:38 AM   #15 (permalink)
George Tyler
I just check to see if I can add an indicator light for lockup on my Previa, I connected a led diode and series 1k resistor to +12V so it will go out when lockup is enguaged. Supprisingly, the 12Ma it takes cause the RPM to drop at idle! no way 12mA will pull in a solendiod, it must have some electronics in the gearbox.
